Re: Whats for Launch?
Heres ya some good information!
http://www.syty.net/forums/showthread.php?t=19577
How to get a killer 60'
Lots of people have asking me about my 60 ' so I thought I would make this post on what I have and do.
These are the parts I have:
1) green dot tires
2) HD Bilstein shocks
3) Caltracs
4) Suspension travel limiters through both upper control arms.
5) Digital 6 MSD using the 2step on the launch.
6) Pressure switch set at 6 psi in series with the 2step trigger wire. This makes it build boost faster.
What to do with that stuff:
1) Let the tires down to 20-22 psi on all 4
2) Load the rear springs with 1/2 turn on each side with the caltracs.
3) Turn the travel limiters where the end of the stop is 1/4 inch from bottoming.
4) Set the 2step on 2900-3200 depending on track conditions. (The 1.47 was at 3100) you will have to play with this some. I have a 3500 stall.
The fun part:
1) I cool the truck down to 145-150 deg before I go to the lanes leaving the hood open in the lanes to keep it cool.
2) Flip the tq converter lockup switch.
3) Drive around the water and backup close to the water but dont get in it while making sure I am lined up straight.
4) Mash the brake as hard as I can and put the throttle to the floor. When I see 15psi on the boost gauge let off the brake and let the tires spin to clean em off.
5) Start pulling up to get pre staged making sure of being straight and in the groove. If it is not I back up and correct it.
6) Creep up very slowy to the staged beam and stop just as it turns on to stage as shallow as possible.
7) Mash the brake hard and put the throttle to the floorand hit the 2step button.
8 Let off the brake and step button on or maybe a little after the last amber.
9) If it starts spinning I am ready to lift some and then go back down with it. I have not had a spinning problem lately tho.
10) Keep it in the groove and as straight as possible going down the track.
I hope this helps someone. This is the longest post I have ever made I think :fadein:
__________________
Phillip Long
