midnightbluS10
Banned
Re: Transmission problem maybe computer?
Theres a post missing from pg 1. Anyone remember what it said?
Didnt it say he used synthetic fluid? Maybe, maybe not!! I vote that you got ripped off on there being a new trans inthere. A plugged trans filter, low fluid, shot pump ect.... If the fluid level is at the right level an its nice an red!! You will need to start to remove your trans an have it gone through!! The ECM does NOT controle the trans on a 700r, if your tourque converter is draining that sounds like the TC is severly over heated an pushing the fluid out of it. Reguardless of anything i would begin to remove the trans an become really good friends with a trans shop!!
Ok i fixed the problem,, it was the transmision filter its was so clogged with old oil and rust luckally only a lil water got in there everything else looks new and clean ill post pictures
