91syclone832
Banned
Im having a problem witth my trans. I put it in gear and its fine for a minute the acts like its in neutral and when i reset the computer it works again but does the same thing
ok heres how i know its something electronic.. ok heres what it does if i cold start the truck and put it in gear its fine to drive around the block a few times, i put it in gear r,od,d, for a lilttle bit to try to use all the gears and all is perfect transmission shifts nice right on time i can even do a 180 tail whip because im 2 wheel drive right now, so i can drive it till it gets hot then the transmission starts acting up like it took a shit so i can go anywhere no gears nothing(i had slipping transmissions before and i know that all the gears just dont go out, so its not the clutches) but when im stuck i just take out the ecm fuses put them back in and instantly i can drive again but when the engines hot and i do this i can only drive for a block then it cycles again, im guessing it has to be the computer or a sensor on the transmission
does not wine everything is normal till i hear the fluid being sucked out the tourque converter, my truck will go no where and doesnt engage into any gears i can rev it in any gear but if i reset the computer real quick it will go into every gear and works good sometimes it firm shifts sometimes a smooth shift into second gear but i have not gone into od i chased down a wire from a sensor in the transmission to the small ecm attached to the big ecm brain... does any one know what that is for
