Re: Yank vs. 9/11
If you already have a 20g why don't you use it and go as fast as you can with it. The 74 is a decent size turbo for a vortec/cam build. You already have it so why not hold on to it.
I tried a phil long chip and liked the WOT performance but the drivability sucked, way to rich idle and part throttle. I went BS3 and didn't look back! The stock intercooler with full flow lines and a Johnson pump does great when your moving, with higher boost 17-18psi it raises temps really fast at the track by the end of a run.
I'm making one more trip for a 12 and will go to a razor alky kit as my next mod. It will be much easier to tune for the alky with the BS3. More timing/boost I'm hoping will yield a 12.50 I remember using the first gen razor kit with a 50# ultimate chip. Wot was awesome, although drive ability sucked. I could not take out enough fuel to allow the room for the meth even with the progressive spray.
Nothing really to call a build in my Ty, just a 20g with l35 heads and 50# injectors.
I am still debating on doing the trade. I would like to pick your brain more about the PT74 though, or rather the rest of the parts to go with it...since you seem to have plenty of knowledge, and are willing to answer. Vortec heads, stock or ported...or either? Cam, which one, or custom? Convertor, what stall? Injectors, how many #'s? Tuning, would a Turbo Tweak chip be able to handle this build? Built motor and trans, I would assume.
You have me a bit worried about the Phil Long stuff I just bought. I will be WOT some of the time, but not very often. I don't want it to suck driving it around the rest of the time.
Yours may be a more basic build, bolt-ons, but it still an improvement over stock...and you are making changes.
Cam
