V8 Sonoma GT
Mile High SyTy
Re: Yank vs. 9/11
so here is the update. i was much closer to sea level (2k feet, in NE) even with the red spring, it would push thru the brakes at 6-7 psi. (would not spool fast enough, and i have LS1 brake upgrade). back up here at 6k feet it wont get past 4 psi. i was in the same place in NE last turkey day and i would not make more than 17 MAX psi. now as picture shows (middle gauge) high reading. keep in mind also, that outside air temps were way way lower in Nov in NE than yestersday (20s vs 90s) and still runnin liquid to air, it was heat soaked big time yesterday. still almost crested 20#s. whereas the forge would prob have me at 21, maybe 22 in the cold. keep in mind i have went from velosyty to code59 also since then, so the WB should only help.
My verdict, of which Mike agrees, the forge gate accuator WILL NOT spool stock convertor at 5000+ feet. Sorry. Hell it barely worked at 2k. Believe me I LOVE the Forge, but it is not enough. Maybe with the addition of L35s. Maybe on my Braphoon project hehe. But the TY gets the Yank, and then hopefully we see results.
