I just traded for a TE61 turbo and ATR DP and external wastegate setup. The exhaust housing is the three bolt kind that requires the adapter. The exhaust housing has no writing or markings on it and the turbine wheel, as best I can tell using calipers, is 61mm diameter
1) I have read the adapter sucks. Is it because it leaks? Is there anything that can be done to improve the adapter?
2) Is the exhaust turbine side PTE 3 bolt or Garret?
3) Where can I find compressor maps?
4) Will it be a good combo for my 3k rpm stall converter and ported Vortec heads?
5) Should I go to larger injectors?
Any answers or other info you can share about this setup would be greatly appreciated.
