Performance engine component pn's
E-Rue
this is the complete number for the stokes grind comp cam.
Comp cams part # 09-422-8
Grind number is 270AH-R14
JE pistons are 131636? might double check that number, as im not sure which ones those are.
e
ed hess
race or get outta the way
comp cams chain 3136
comp cams lifters 85012
oil pump melling M55A (per myclone)
flexplate B&M 20239
Balancer to crank bolt ARP 1342503
cam to gear bolts ARP 1341001
Oil pump driveshaft (hardened) ARP 1347901
gasket for vortec heads to lower intake felpro 1203 (per waller)
ed
ed hess
arp just told me for flexplate to use 200-2807 which use 5/8 socket instead of the standard no which use a 3/4 socket which wont fit on the end of the head without grinding it down.
wouldnt ya know it my vendor doesnt have it in stock AAARRRRR!
Hu Ryde
Ok, just updated and cleaned it up some. See what else I'm missing. Time to go back to school.
ed hess
heres another number for you
When checking piston to valve clearance you must use a solid lifter.
The 412 comp cam uses hydraulic lifters no 850-12. For a solid lifter use
camp cam no 818, in a quantity of one it is no 818-1.
You only need to check intake and exhaust on no 1 cylinder least thats what comp cams told me today on the phone.
ed
Falco
Jesse,
The pushrod part numbers seem to be wrong on your part number page. You listed ~7.8" length pushrods, while the stock length is ~7.2" IMHO. Pls correct this. A Comp Cams part number is 7808-12 for the stock length for example...
Later,
MikeRenz
not stock
can you take off the [stupid] javascript for the status bar that says to donate $ and continuously scrolls text. Just put a blurb on the bottom of the pages to say what you wanna say. I hate when people use the status bar like that. [/rant]
imho you should get rid of it. take it fwiw.
Hu Ryde
Sorry guys. Didn't know it created errors. Dreamweaver said it would be compatible with all browsers. Worked fine with my Nutscrape 7 & Latest IE. Anyway, it's gone. Later
Falco
Jesse,
Have you seen my comment regarding the pushrods? It's above the rambling. :roll:
Later,
CLONE
Thanks Jesse! Dreamweaver doesn't and can't take into account individual browser settings.
ramble ramble ramble
Thanks again!
