Re: worn rag joint ?
I did the astro shaft from 2000 year, wanted $50 got it for $25 with discount.
I love the mod, fixed steering slop alot but did the comlumn bearing upgrade also mine had alot of play there.
I did have to reclock which is not hard, but a steering wheel kit to remove and install is alot easier.
also the search find i found had me reclock the wrong way for my shaft, had to reclock the other way.
fixed and very happy. also note that you car hear the woosh of the fluid from up the shaft but only at idle or low rpms turning. there is not rubber isolator.
