will these offsets fit our trucks with spacers or with not 18x9.5 +53mm 18x10.5 +50mm thanks John
X Xplicit Racing Design New member May 13, 2002 #1 will these offsets fit our trucks with spacers or with not 18x9.5 +53mm 18x10.5 +50mm thanks John
InvisiBill Active member May 13, 2002 #2 http://www.sytyarchives.com/howto/wheel_tech.php FYI, the rear wheels need 28mm more offset than the fronts to retain the stock alignment. That's pretty close to a 1.25" spacer if you get four fronts...
