Wheel Bearings?
John C Holmes
Can anyone give any info on them? Like say do they make a noise before going out? Are they self contained or can I pack them? Can I find them on any other vehicle? How much at the dealer? And last can I do the replacing or packing or whatever myself?
tia
Cody
4C FED
Absolutum Dominium
It's a hub & bearing assembly.
You won't be able to clean & pack, just spend and replace.
My memory is pretty poor, but I think the bearing/hub assy. was in the $150 range.
Try NAPA.
You should be able to do it yourself. You just need a big socket & a long 2' breaker bar to get the axle nut off. Also might need a pickle fork/ball joint separator. It's been awhile since I had mine apart.
HTH,
The Timken replacements are $110 at AutoZone. They look pretty solid - the only bad thing is that each AutoZone only stocks one at a time so you have to go to two different stores or order the 2nd one in.
The bearings get sloppy when worn - it should be obvious if it needs replacement.
myclone
Rear bearings are replacable but its kinda uncommon for them to fail. They arent packed with grease as the rear diff lube keeps em lubed (as long as the fluid level isnt allowed to get low).
myclone
92 black typhoon said:
So if you pull on the part that has the studs it's cool if it moves in and out a little?
Less than 1/8" there about would prolly be considered ok IMO.
Lynn D. Brown
Wheel bearings
Wheel bearings
So, the rears get lubed w rear oil - how about the fronts ? I don't think the front diff oil can get over there. Do U pack them w grease ? Do they adjust like 2WD whl bearings ? Tighten until drag, then back off ?
hideakimura
NipponSyTy
I need to get 2 of them for front and tried to find them but it was sooo expensive here in Japan.
So could someone tell me what's the p/n and where can I order those from Japan??? summit? jegs?
V
Hub/bearing assembly...7470005
Might need the Inner Bearing Seal too...560680
I don't think Jeg's or Summit carry those items.
