TYTILIDIE
METH HEAD
I have a problem here that is getting old real quick. I built this POS tranny, first one Ive ever had problems with, the reverse doesnt work. I had the pan and valve body off a few weeks ago to try and figure it out. Everything seemed ok except that a check ball in the rear was missing (installed INTO the the case). If you put it in R, you can feel it obviously goes into gear, even rolls back a bit, then stops. If you give it gas it does nothing but when you let off, it rolls back a little morethen stops again??? :dunno: If someone can point me in the right direction or give me something to look for Ild apprecaite it. Thanks in advance.
Mike
Mike
