water temp guage fitting question
jhacking
Hacker
I am wondering where to put the fitting for the water temp autometer guage for a a good acurate reading
jhacking
Hacker
guage fitting
guage fitting
I guess no one has any good ideas for me or i am just asking a dum question.
4C FED
Absolutum Dominium
There are not a lot of options here.
Either you plump a T where the stock sensor is, which won't give you a very good reading or, I don't know if it is accesible, use the pass. side head water temp port. Just like on the drivers side.
BigAl...
Is this a mechanical guage or an electric guage? If it's electric the sender is NPT and you can just drill and tap the water neck, if it's mechanical you can still use the water neck except you will need some different fittings. That's where mine was and never had a problem.
BigAl...
