GEN3Typhoon
Well.. I had the truck ready to run today and just happened to have decided to drain a little oil out of the truck to see how it was after running the motor for a bit.. to make a long story short.. milky.
So I pulled the intake and spacers, mine are aluminum incidentally.. and the epoxy that I used to bond the spacers to the intake apparently could not take the heat and the coolant.
So to my question.. are you guys just using silicone in between the spacer and the intake or what... my other idea was to make a gasket for the spacer... we have some 1/16" or 1/32" silicone at work in sheets that I could use. Just curious as to what the rest of you are using... I read the article on Tyclone and this part of it was not real clear to me.
Other than that the truck runs great, thanks to BG and Nightdiver sending me some starter programs.
TIA
TIA
