vibration at 65+ mph
atkonkler
Is this your bush?
so when i start getting into the ty at about 65+ it gets a vibration i had the front stock drive shaft rebuilt two years ago! anyone got any ideas? I really need to get it on a hoist i know i know! Ive been thinking about getting a heavy duty shaft and scrapping the stock shaft! Which one is best? Opinions are welcome!
blacktyaffair
Re: vibration at 65+ mph
I went with a D&R last year and I'm happy with it. I drove to nats last year with the stock prop shaft and had a slight vibration issue that was remedied with the install of the D&R. Better to spend the money on a strong prop shaft than to fix the damage caused by a prop shaft failure. We got to see the aftermath of such failure at nats. The damage was mild, managed to break the corner pan rail causing a major leak all over the track. A failure usually takes out the whole case. A loop is also good investment, if you can find one.
