gkrcr882
SyTyless......for now!
"BULLETIN NUMBER:
92-7A-139 SECTION:
7A NUMBER:
4 CORPORATE
REFERENCE NUMBER:
267106 DATE:
October 1992 SUBJECT:
SHUDDER/VIBRATION UPON TCC DISENGAGEMENT (REPLACE TORQUE CONVERTER) MODELS:
1992 TYPHOON CONDITION:
Owners of some 1992 Typhoons built before March 2, 1992 (transmission Julian date 2 062) may comment that there is a vibration or shudder when the TCC disengages while under a slight acceleration. CAUSE:
The TCC vibration or shudder may be a result of the damper springs in the TCC bottoming out. CORRECTION:
Transmission assemblies built after Julian date 2 062 will already have the revised torque converters. If the Julian date is before 2 062, the transmission was built without the revised torque converter. To correct this condition replacement of the torque converter with a revised unit (P/N 8687990) is necessary. SERVICE PROCEDURE:
1. Check the Julian date of transmission as shown in the "1992 Sonoma and Jimmy Service Manual", Section 7 Automatic Transmission, page 7A-1, Figure 1. If the Julian date is before 2 062 proceed to step 2. 2. Refer to Section 7 Automatic Transmission, Preliminary Checking Procedure and Noise and Vibration Analysis, page 7A-3 and the Torque Converter Clutch (TCC) Diagnosis on page 7A1-5 to verify the shudder or vibration complaint. If complaint is confirmed, proceed to step 3. 3. Remove the transmission as detailed in the "1992 Syclone, Typhoon and Sonoma GT Service Manual Supplement", page 7A1-9. 4. Replace the torque converter. 5. Reinstall the transmission. NOTE:
When Reinstalling the transmission, make sure that the transfer case TV cable, and fuel lines are properly routed to prevent rattles by these components coming in contact with the floor panel. Also, inspect the positive battery cable for signs of contact with the exhaust system, replace if damaged. SERVICE PARTS INFORMATION
Part Number Description
8687990 Torque Converter Clutch Parts are expected to be available on 10/12/92. In case of limited inventory, parts will be placed on 400 control to waive VIP surcharges. Only verifiable emergency orders will be accepted. GMSPO will make every effort to obtain parts, However, the part will be shipped premium transportation at the dealer's expense and all other order types will be placed on backorder until the 400 control is removed.
WARRANTY INFORMATION
Labor Operation: K7020
Labor Time: 4.6 Hrs."
92-7A-139 SECTION:
7A NUMBER:
4 CORPORATE
REFERENCE NUMBER:
267106 DATE:
