turbo question
I have a te44 on my sy and I would like to know how hot the compresser is supose to get mine gets hot enough to make a sizzleing sound when you put water on it after a pass. I am only running 14 psi.
TurboManiacal
I'd suppose puting water on a compressor that regularily gets hot would cause it to crack...but I'm not an expert.
smeagol
they have actually done water cooled exhaust housings in the past...
i forget what it accomplished
Methuselah
Do you mean compressor housing? I imagine you would want the two halves of the turbo to be at opposite temperatures extremes. The exhaust housing wrapped and/or coated to keep the exhaust gases moving as quickly as possible, and the compressor housing as cold as possible to aid in its efforts to create as dense a charge of air as possible.
That is to say that I cannot even reason out why cooling the exhaust housing would be beneficial.
________
Herbal Vaporizer
