http://www.huryde.com/html/Tech/mofoturbo.htm
S smeagol Active member May 31, 2002 #2 Probably best to just take the exhaust housing completely off the turbo. I'd also transition that port job into the regular neck of the turbine a bit better. Thought i'd throw that out there.
Stangbeater How bout it? May 31, 2002 #4 http://www.techweasel.com/articles/syty/rebuild.htm Has a good one under June 28 date.
S smeagol Active member May 31, 2002 #5 Yep that one was done very well. You don't have to make it look beautiful, air is blind but any little bit helps.
T TheObiJuan Active member May 31, 2002 #6 You don't have to make it look beautiful, air is blind but any little bit helps. Click to expand... haha, i like that, that is so damn funny. :lol:
Hu Ryde Donating Member May 31, 2002 #7 The last image was with the carbide bit only, I have yet to get to the stones. After the stones I will be going over the whole inside of area that was removed with a sanding drum. So that's were I was so far. More to come!
