tuning
gringo76
allrighty guys, I got a tuning issue and see if its something you guys have ran into before.
when I first start truck cold or hot it goes pig rich like low 10's afr basically flooding out, I clear it up for a few seconds and then it idles at a normal 14.5-15 afr. does this every time I start truck. The rest of the data master idle readings are,
kpa-50, tps volts-.43, tps %1.2, iac-46, rpm-900, lterm-140, sterm-131.
mods are vortec heads,e85, 80lb injectors, walbro pump,3 bar map, turbo tweak chip, sm cam, bigger throttle body, precision turbo, aem wide ban ran to f14.
anything I should look for before I waste erics time at turbo tweak?
it would also go pig rich when I put it in gear so I adjusted the idle fuel knob on the chip itself and cleaned that up a bunch and only drops to low 12's in gear now but did not affect the starting rich condition.
0966Sy
Code what?
Welcome to the world of OBD1, it sounds to me like either the timing/cam is wrong with the tune or you have a vacuum leak. What's the cruise AFR? If everything checks out you need a adjustment in the chip. Does your chip have a wideband patch?
gringo76
Re: tuning
lol old computers. cruising afr is around 14-15, and chip was made for the aem wide ban to be hooked up threw computer . right off hand just the idle seems to be jacked up, but have not floored it yet. checked for vacuum leaks and cannot find any
gringo76
Re: tuning
One thing to check is correct setting on wide band O2 controller. Don't ask.
Uhm , mine is the aem and was just the gauge and wide ban sensor. Does not have a control box like some of the rest. I'll read into it just to make sure
