Little U-Joint :( What i need for repair?
Robert Lone MUTANT Apr 3, 2006 #2 Re: Trouble with front prop shaft GILBERT would be a good start. I'd "guess" it to be the same as a 4wd S-10 u-joint. Prolly wrong though...
Flint New member Apr 3, 2006 #3 Re: Trouble with front prop shaft T-56 said: GILBERT would be a good start. Click to expand... What is "Gilbert" T-56 said: I'd "guess" it to be the same as a 4wd S-10 u-joint. Click to expand... Have part number?
Don W. Stab it and steer it Apr 3, 2006 #4 Re: Trouble with front prop shaft The stock front drive-line is notoriously weak. "Gilbert" is an after market shaft that is bullet proof. Do a search and you'll get all you need to decide.
qbnkiller Conflaguration Specialist Apr 3, 2006 #5 Re: Trouble with front prop shaft or you can get a replacement front driveshaft from me. I have information in the Group Purchase section.... http://www.syty.net/forums/showthread.php?t=35833 Alex Esnaola Typhoon #1600
