transmission leak
4C FED
Absolutum Dominium
Re: transmission leak
Your converter is bad, send it to me & I'll dispose of it.;)
With gravity and such, I'd say the pump seal is leaking.
JuStBlAzIN
I knew it..I should have never trusted the billet 9/11. I will personaly go and drop it off when you wake up from your dream. ;)
Is it hard to change out the pump seal?
4C FED
Absolutum Dominium
Unbolt trans, remove enough stuff (technical term) to allow removal of TC.
Remove seal
Install new seal with loctite.
It's a metal clad seal. I'm pretty sure there's a seal installer tool to put it in, but I think if your careful, you could do it without the tool.
JuStBlAzIN
Remove seal
You are talking about the seal that mates with the TQ shaft right?
4C FED
Absolutum Dominium
Yeah, I think we're talking about the same thing.
Goes around the outside of the tube on top.
http://images.circletrack.com/techarticles/general/139_0502_torq_1_z.jpg
