Re: Transfer Case r&r question
If you're talking r&r the xcase without moving the engine/tranny, easy as cake. 1. Put front on jack stands. 2. remove rear drive shaft. 3. remove prop shaft, putting truck in neutral to reach bolts. This is why you took out the rear drive shaft first, so you can spin the front tires. 4. unbolt xcase and tranny, unhook electrical connector on top of xcase and slide her out. I don't think you have to remove the cross brace either. Any q's, just ask, we'll be here if they aren't too dumb
