Re: Trans rebuild
It depends a lot on how big you're looking to go. If you want an 11.00 SyTy 700R4, it's gonna be different than one built for mid-low 12s.
My current refreshed trans is pretty much stock parts, with the exception of the reinforced input drum, beast shell, and a decent set of clutches. I also ditched the fairbanks 1-2 servo for a stocker, and added a slightly better 3-4 piston/cover to combat a leaky+loose stock unit I had.
I had alto reds (9 disc) in it, and they looked good coming out. I put Raybestos blues back in, just to try 'em, with new steels. I had a wide red-lined band, and found it to be kinda burned. I went with kevlar going back in, we'll see how it goes.
The clearances are super critical. You can't skimp. New bushings everywhere. Check endplay, and fix it if it's out. Check clutch clearances, and do what needs to be done to get them right. Most of the time, "whatever" is what you get from a trans shop.
I'm expecting this to live through mid-high 11s. The only other thing I'd possibly consider doing is cryo treating the output shaft. I'm fairly careful about how I run things, though, and I try to keep the chatter out of the driveline.
You can build a super-killer 700, but I'm not convinced that all the billet parts and cryo-ing everything results in longer life. The loose nut behind the wheel has more to do with trans life.
