Re: trans install
While I have done a *few* swaps in my time with help, most have them have been by myself. My method is as follows:
First off, do yourself a
BIG favor and buy a transmission jack for roughly the price that you would pay for an "adapter" to use your floor jack as a transmission jack. It makes manuevering the transmission under the truck
SO much easier because it has swivel casters on all four corners instead on just one end like a floor jack.
"Every syty owner needs one of these..."
Even with your average jack stands fully extended, you will discover that the truck still won't be high enough to get the transmission out from under the truck and vise versa. If you have a nice aftermarket transmission pan, you may want to swap it out with the stock one so that I doesn't get banged up in the process of the pull. You are going to have to drain the transmission anyhow so, just take it off. You can slide it out from under the truck on a piece of plywood or cardboard to protect the pan if need be.
"Transmission carnage, BTDT three times so far for me, five times for others..."
The "trick" to get the transmission on and off the jack by yourself is as follows. You will want to have several short lengths of 4X4's and 2X4's on hand to act as shims to shore it up as you raise of lower it off the transmission jack. Getting if off is easy, all you have to do is put the appropiate blocks under the tail shaft so that the topmost one is close to just touching the bottom of the tail shaft. On the bellhousing end, put a few blocks under your elbow so that you can get your palm under the "peak" of the bellhousing. Pushing up on the bellhousing will make the transmission tilt back on the blocks under the tailshaft. Thus allowing you to slide the trans jack out from under the transmission so that you can set it down. If you don't think that you can hold the transmission up long enough to slide the jack out from under it, don't sweat it. Just slide a 2X4 under your elbow as soon as the push the transmission up high enough to tilt it back. At that point, you won't be staining your muscles as the weight will be supported by your bones.
That's getting it off the transmission jack. Getting it back on requires the same procedure. Start off by putting a block of wood just under the tail shaft and using the same "push up on the bellhousing" technique outlined above, slide a block of wood under the front of the transmission pan. Now here's the easy part. Laying flat on you back under the truck, grab the top of the peak on the bellhousing and pull staight down and you will be able to lift the tail shaft off the block in the back. The bellhousing acts like a big lever so that you can put another block under the tail shaft. Alternate between shoring up the tail shaft and the blocks under the front of the transmission pan until the transmission is high enough that you can get the transmission jack under the pan. Usually, I just push all the blocks that were under the tail shaft out of the way with the transmission jack itself. Just make sure that you keep the blocks under the front of the pan far enough forward that you can get the transmission jack under there when the time comes. The effort to do this is laughable and I never dread having to do a transmission by myself.
The transfer case *only* weights around 70 pounds so, you shouldn't have too much trouble installing it by yourself. If you didn't drain it and it tips the right way, you may get a ATF shower... Get a new gasket, part number 1564-2511 to go between the transfercase and transmission too. The gasket has an orientation so make sure that yo can get all the bolts started before you button it back up.
Just a few more "tips", make sure that your torque converter is
FULLY SEATED on the pump of else you
WILL damage it using the bell housing bolts to "crush" it in place:
"Fully seated torque converter. With a straight edge across the front of the bellhousing, the distance to the mounting pads should be approximately 1 inch."
Also, be sure to use Loctite 262 (the red stuff) on the torque converter to flexplate bolts so that they don't loosen up.
If you still have the stock downpipe bracket, trim back the sheet metal while you have the transmission out to make getting that topmost stud out
MUCH easier the *next* time you have to pul the transmission:
"If you have ever pulled your own transmission before, you know what's up with this. Primed and painted afterwards..."
And last but certainly not least if your previous transmission grenaded, be sure to
FLUSH your lines and stock cooler or else you risk running shrapnel through your freshly rebuilt transmission:
"How transmission lines and coolers get flushed..."
On one pull that I helped with, the lines and stock cooler were so plugged with debris that nothing would flow through them. On another, the old ATF was so burnt that it came out as black as ink and it took several quarts to flush out. HTH's
