sy#2921
BAMF
Over the winter I swapped out my roadmaster 700 for a waller 700 and also swapped converters as well. It had a yank I believe (red in color) and am using a coan now.
My concern is this,
I measured the TC engaugment with a flat edge from the bellhousing and came up with an inch like shown in the pics floating around in Mike's post (sy2932).
Now when I took out the old trans after unbolting the old converter from the flywheel i moved it back and used a homemade strap to hold it in place so it didnt slide forward or off during remove NOTE: at this time there was clearance between the crank snout and the hub on the converter.
Come to install of the new trans. I use the same strap the hold the converter in place and it fits the same. Now this time I get the trans in place and bolted up and notice the hub on the converter is up against the snout of the crank. It rotates freely but is noticeable closer than the old converter when slid back.
At this time I took the trans down and tried to reseat the converter, remeasured got an inch, put the trans back in the truck and the same result, converter hub is up against the crank snout but rotates freely.
Does this sound like the converter is still not on the input shaft of the trans correctly still? Or is there a difference in converters I am seeing?
My concern is this,
