John is absolutely right. The Fairbanks 4th gear servo is junk. I have only put it in 2 trannies(mine and Jesse's). It stuck in both of them. Jesse's wouldn't go into 4th after a while and mine would go into 4th(delayed)but then had trouble releasing.
Right now I am using the stock 4th apply and I am having no problems with 4th.
If you do use the Sonnax unit, the problems go WAAAAY beyond false knock. The unit is so large(sticks out of the case so far), that during the 1-2 shift, the servo hits the floor pan. This puts extra force on the 2-4 band and will punch right through the lip that the pin pushes on resulting in no fourth or 4th that "neutrals out" under slight addition of throttle. If you must use this unit, bang the floor away from area around the servo cover or cut the floor and glass in/weld in new metal that arcs up away from it.
The big thing is 2nd apply and 3rd apply. If you build the input according to the new design and use Alto Reds, 3rd will apply like a hammer.
HTH,
Blake
