On 2002-02-20 15:11, Hu Ryde wrote:
What about this bad boy, a Flex-a-lite![]()
It's: 7 1/2 x 12 x 3 1/8 How big was the Permacool?
I plan on putting a huge cooler in with a fan and all.
On 2002-02-20 14:32, RAACCR wrote:
Rick & Jesse,
I used a pair of the B&M Street Rod coolers on the old build-up of my original Sy. I mounted them flat below the foglights; tranny on the passenger side, engine oil on the driver's side. I ran both of them in series after the factory coolers in the radiator, and used a 142* thermostat. (I'm sure the lower coolant temps help the factory radiator coolers extract more heat from the oils.) I never had a heat related problems, even running a 4k stall non-lock up in the South Florida heat. If you need some feedback from someone who has mounted coolers beneath the bed with a fan, contact Gary Shanock...he has a tranny cooler set up like that.
If you run an ATR aux. heat exchanger, that pretty much rules out installing a tranny cooler in front of the rad. So you would need to locate it somewhere where direct airflow would not be optimal, hence the need for a fan.On 2002-02-20 16:24, E-RUE wrote:
im just curious, not being a smart ass, but what is the fan for?
i installed a BIG tranny cooler on my truck. its slightly smaller than the AC radiator, and it never even gets hot to the touch. im just wondering how much more efficient it would be with a fan? BTW, i removed my AC radiator, since it wasnt being used, and bolted the cooler in its place. ill try and get a pic or two up tonight.
e
On 2002-02-20 17:58, RAACCR wrote:
I bolted the cooler flanges directly to the lower lip of the front bumper beneath the fog lights. The coolers laid flat along the lower edge of the bumper (parallel to the ground). I used 90* fittings into the ports on the coolers. And, I secured the oil lines to the bumper braces with tie wraps for additional support and to keep them from rubbing on anything.
On 2002-02-21 01:53, Tommyquest wrote:
do you have any pics of the cooler mounted to the lower lip?
Sorry, no pics of the old set-up.
