Timing question
WS6Clint
Small question on timing. Do you disconnect the tan wire then start the truck and set the timing with a light like on any other vehicle or is it different? Just want to know before I start so I dont screw things up any worse than they are now. Thanks
4C FED
Absolutum Dominium
Start it up then disconnect tan wire.
Attach timing light just like any other car to #1 cyl.
Adjust if required.
When you're done re-connect tan wire.
Disconnect + bat. terminal to clear code.
Start it up & drive it like you stole it.
