mrweelr
I installed a tie down chain first and hooked the top to the back of the alternator bracket and the bottom to a hole I drilled in the frame. Realizing that chains are not a good idea due to vibration, I did away with that setup and installed a heavy duty nylon tie-down strap with the top hook connected to the alternator bracket and the bottom connected to the front control arm bolt. This setup did not work out and the strap ended up breaking. I'm going to give it another try with a stronger strap but my question is, "what are you guys hooking the bottom of your tie-downs to?" I don't want to use the control arm bolt and I'd like to avoid drilling any more holes in the frame. Suggestions?
