Tie Down Cable
Hu Ryde
1 Go to local Auto store and buy a tailgate cable and a grade 8 bolt.
2 Jack truck up and remove front driver wheel.
3 Attach cable to bolt behind alt.
4 Route cable down to frame and drill hole so there is very little slack in line.
5 Move cable out of the way and tap the hole to accept grade 8 bolt.
6 Run the bolt through cable and into frame.
If you want put this on the archives.
0966Sy
Code what?
Good link, So does this help get the front driver's side tire off the ground? LOL
I have not yet done this but will be installing it this weekend.
Erik'
AXXE
It looks good. I was not so sure about using the tie strap with the ratchet. I am going to try your install.
jhacking
Hacker
How is that bolt going to hold up just being that it is just taped into the frame rail, and not fastend on the back side of the bolt just thought.?
Hu Ryde
Mine has held up for about 8 months. That's with launches and everything else that comes with a Sy. I guess it would be possible to get a washer and nut back there but I have had good luck without, ok where is some wood to knock on......
Ian Turgeon
Cascading Inspiration
holly crap.. and article to use.
thanks, ill get it up when i can manage
(homework, sytynats t-shirt, sytynats plaques, sytyarchives, web buisness, syty nats personal project.. ug.)
ivanko
No drilling required.
I bought the HELP! tailgate cable for GM Blazer & Jimmy PN#38511 from Kragen. It's the perfect length to connect the bolt just above and to the right driver side sway bar mount. I routed it between the two oil lines going to the remote oil filter. It looks like there shouldn't be any contact when the engine lifts, but I will check for clearance anyway. I don't want to put any unnecessary holes in my Syclone. The black cable looks it belongs there. Nice OEM look.
Adam Auerbach
GMC Syclone #2419
Mitsubishi Galant VR4 For sale!
