tack flutter??
turbokll
hey guys. got a little problem. just got the sy up and running, but my tack is all over the place at idle? but the truck is running great. also the mph gauge is at 120?? any ideas?
Falco
Ignition problem? When did you tune up your ignition system last time? Spark plugs, wires, cap, rotor maybe coil as well.
In most of the cases tach fluttering are caused by a bad ignition system. The speedo could be the same, but it could be something else as well. Tune up the ignition first, then we will see.
HTH,
Loeryder
SyTyFaQ to your left said:
My Tach keeps fluttering What causes this? Telltale Ignition problems. Do tune up with the above listed products.
See the SyTy FaQ and go through your ignition... again.
turbokll
new cap , plugs, wires and rotor were done. if your not looking at the tach you wouldnt know anythings wrong. and when i rev it up it dosent flutter or miss a beat?
