T-Case woes
Merk
Hi guys,
I'm trying to get the FILL plug off my T-Case. It's jammed in there.
Tried a couple hits of PB Blaster; no help.
Any ideas?
jwaller
Evil Genius/SyTy Guru
Re: T-Case woes
I always smack the bolt/nut whatever with a hammer dead on and this will force it against the slop in the threads thereby braking loose whatever rust/junk was holding it. also might try some heat on the outside of the case around the perimeter of the opening.
jwaller
Re: T-Case woes
If you cant get the fill plug out and you have to fill it then just pump the correct amount in thru the vent hole instead. I think it's 1-1.5qts. it wont be exact but it should be close enough.
Beavis
Still plays with trucks
Re: T-Case woes
I have a portable heat wrench if you need to barrow it or if you want to stop by we'll get it out. :tup:
psmvchaser
Re: T-Case woes
Same here. If you need any help or tools, let me know.
