Gnocide
turbo game burt reynolds
many leak or people decide to get new ones.
this thread will give you the how to with hand tools you need to put a new TB on for under $200.
(depending on brand and size-52-58 mm etc)
assuming you've removed your tb ...
buy a tpi throttle body like this 52mm from somewhere>
http://www.summitracing.com/parts/sum-227705?seid=srese1&gclid=CNDq65qArrsCFag7OgodB1QAXg
remove the iac housing from the bottom with the 7 torx srcews
bolt that shit up
next tps sensor has 2 more torx screws
swap that over
now the fun part and 2 differences to make the stock linkage work here.
1) grind off carefully the stock linkage rivit, then carefully pry off stock shaft.
the aftermarket linkage rod is bigger than the stock slots in the linkage so some fileing/ dremel is required to make them fit over the new shaft. do not leave any play or wiggle.
these pics show the aftermarket linkage as i lost the pic from original.
more coming.......
bolt that shit up
swap that over
more coming.......
