Stock Torque Converter Question
teamvortec
I was wondering if anyone had a stock Typhoon converter laying around and could give me the code from the sticker on it? Should be a 4 didgit code something like DCNF or similar. Thanks
teamvortec
Re: Stock Torque Converter Question
92 but if you have a 93 would also be curious. I am gathering parts for my rebuild. I have a factory 2100 stall that also has a brazed impellar I might be putting init. Just curious as to what came in them from the factory. I know what they are rated at doesn't mean that is what it stalls and I have the sheet for breaking down the four digit code so I was curious what they have.
Beavis
Still plays with trucks
Search for corvette torque converter, it has been talked about a few times and stalls alittle higher than our stockers.
Beavis
Dave, I was only useing that as a search referance, not an exact piece of eqp. Do the search and you will find the info and the referance to corvettes and your own info that you addded....
ps, please spell my name correctly......
teamvortec
The DCNF was a factory used in some vehicles that according to GM/Dayco build sheet is a 2175rpm stall speed with a brazed impellar. I have a couple of those at my shop and was thinking about using one of them in my rebuild. That is why I was wondering what was factory just trying to compare the stall speeds.
teamvortec
Well I got my trans out and the sticker was not on the converter. I have 2 converters at my shop I can try one of them is a DCNF and the other is a DCLF. Which one would you say go with? On the sheet is says the difference is 110# vs 100# and graphite clutches vs carbon clutches.
teamvortec
Mainly stock motor and turbo. Might eventually do a boost controller and a chip/tuning. It had an eger delete when I got it and from past reading looks like a po changed the chip, but I havent verfiied yet. I am adding a Walbro pump and afpr already had hot wire kit on it. Not going to wild on this one but I do want to add a little more power. I really don't want a 2800 stall with driving it once and while on the street but would like a little more than what it had factory. That is why I started thinking about the ones I had here at the shop since they are 2000 stalls.
