TYTILIDIE
METH HEAD
Paragraph 1- I have had a slight sticking going on in my throttle body for a LONG time. I know it's bad I just now did something about it but truthfully, every time I looked at it I could never find out why it was doing it. What I found was, if you look at the groove where the cable goes, you can see that in the upper right (in the pic that is) it grooves in to a point.
Paragraph 2- In my situation, I would let off the gas and have the throttle stick to about 1500-2000RPM, just a little bit. When I figured out the problem, I noticed that if I opened it by hand and let off of it softly, it would stick about 1/8-1/16" open from the idle screw. If I wiggle the cable, the cable would kind of snap a little and the throttle would close all the way.
Paragraph 3- Basically what was happening is the cable was getting kind of pinched in that groove you see. To fix this, I cleaned it up real good and dropped in a little JB weld in to the groove. I know it sounds kind of ghetto but JB weld will smooth out and lay pretty much flat in to place, this is the main reason I used it.
Paragraph 4- So far this has been a perfect fix for me. If your throttle ever gets stuck to where you have to snap the pedal a little to get it to come back down you may want to look in to this. I know that my other throttle body I had did the exact same thing as well. I have also driven two other truck that have this issue.
Paragraph 5- Oddly enough, the problem did not always exist but when it did it was very annoying. Sorry for the paragraph note had to do it for some members here:lol:
