sprag replacement
What is the estimated cost of replacing the sprag? If the sprag is toast would it be recommended for a replacement transmission?
turbodig
Re: sprag replacement
You can't just replace the sprag... it will take other things with it.
A rebuild of the trans will be necessary.
SYO237
SyTy Registry
I think the sprag assembly is around $40-60 I believe and if its toast in your truck, you need to rebuild it amongst other things that probably got shredded with it. Also, make sure whoever does the rebuild, to get the hardened heavy duty sprag....ask me how the last guy to build my trans found out the hard way and why my truck is now sitting 260 miles away in someone elses garage waiting for a free rebuild :tup:
