Nitrous
When I bought my Syclone it already had a beefed up prop shaft and the shifter cable bracket was modifiedso it wouldn't hit. I've never been able to shift the truck into 1st because the shifter won't let the cable go back that far or there's something in the shifter stopping it. I was driving around and tried to drop it into first and the cable stuck. I had to push it forward super hard and found the cable wound up inside of itself. I changed the cable out with a new one and everything shifts easy except it still won't shift into 1st and Park is still hard to push into but if I push hard enough the push button will pop up. I'm thinking it's the modified bracket and pulled it off thre tranny and benit closer and further to compensate but still have the same issue. Anyone else ran into this problem with a prop shaft upgrade? I can usually make these things work but it's kicking my a!@..........Also, there's a large vacuum line on the front differential going to nothing and I ve been reading about a differential actuator. Anyone have any ifnfo on this also? the prop shaft rubbed it into.
Thanks,
Lance
Thanks,
Lance
