supersports10
ok, so here they are, 10 pics for your viewing enjoyment.
i finally got it all together and working, with ALOT of measuring, and measureing, and measureing.....
i have all gears, p,r,n,od,d,2,1,
i mad sure i got park, and low 1 every time. i wasnt happy untill i did.
these friggin threaded end have proven to be a bit*h to find, and pricey, but i think im ready to start making these, on a larger scale.
the shift bracket needed another hole, (shown with the screwdriver bit pointing)
which will come pre drilled.
the only mod that was required was a 5/16 hole in the shifter stalk. it was no big deal to drill it, takes 1-2 min, and is never seen. the factory little c-clip thingy wouldnt even come close to working, so i went this route, and am VERY HAPPY with the results.
just for durability's sake i ran this shifter cable through probably 50-60 cycles, trying to get something to break, streach, or come out of aliginment, and it was perfect every time.:tup:
priceing will be 160.00 plus 8.00 flat shipping rate.
this kit will come with the following....
1. shifter cable
2. pre drilled shifter cable front bracket
3. lower shifter cable bracket.
4. 2 10/32 threaded swivels, (man these were expensive)
5. 2 pan spacers for factory style pan, (aluminum pans dont need the spacers)
6. 2 grade 8 longer pan bolts
7. 2 cotter pins
8. a 1 year warranty if installed on a sy/ty/sogt....... yes i said warranty and sy/ty in the same sentance!!!
enjoy.
1. shifter cable
7. 2 cotter pins
enjoy.
