B
Blake
Guest
While trying to set my timing, I had trouble getting the timing to stay steady, with tan wire disconnected, timing and rpm would flare up and down. When going down, the engine would almost die and then flare up again.
In the meantime I noticed that when in park or neutral, if I rev the engine, the truck will shake as rpms go up(compression check was fine).
Are these related? Any ideas?
I found this while looking for ideas:
The Shakedown on Vibration Issues, Underhood Service, May 2001
Motor Mounts
Often-overlooked engine components that may need to be replaced to eliminate vibration are motor mounts. These rubber mounts can deteriorate, collapse and/or separate with age. Fluid-filled "hydraulic" type mounts can often leak, allowing annoying engine vibrations to be transmitted to the chassis.
Most mounts are designed so that separation won’t allow the engine to fall out onto the roadway. But a bad mount may cause a myriad of problems - many easily misdiagnosed.
Often, bad motor mounts allow the engine to rock and move around, causing noise and interference problems with the throttle, transmission and clutch linkages. For example, a thumping noise when the transmission is put into gear or when the vehicle is accelerating is a classic symptom of a bad mount.
Some Warning Signs of Harmonic Balancer Failure in a Vehicle Are:
• A leaking front main seal;
• Visible deterioration of the rubber between the balancer hub and outer ring;
• Visible cracking or warping of the balancer hub or outer ring;
• Excessive engine vibration;
• Slipping, squealing drive belts, belt damage, accelerated belt wear or frequent belt replacement;
• A highly polished spot on pulley grooves (warped balancer);
• Elongation of the balancer keyway or wear on the balancer hub/crankshaft;
• Alternator, power steering pump, air conditioner or water pump failure;
• Engines that do not run properly when adjusting the timing, or poor performance and irregular idle.
Courtesy of Pioneer, Inc.
Motor Mounts
