gdiwicker
Hey All,
Is the servo piston in the trans a 'hard part' or can you rebuild it? I need to know how to proceed cause it's causing a hard shift from 1-2nd. I thought it was the servo spring before I pulled it out but the spring was not broken. The piston is STUCK. I tried everything I could think of to get it to budge but nothing happened. Also, if I have to replace it, is it a readily available part or do I need to find a doner from another 700r4?
