I've got a '93 S10 4x4 with a '99 4.3L Vortec motor in it along with a '91 Scycone transfer case.
I read in the faq
49. Can I drive my truck in RWD without damaging anything?
Making the truck RWD requires removing the forward propshaft. Before removal, make marks on the location of how the propshaft was bolted to the transfer case. The propshaft is balanced, if you dont put it back in exactly the position you took it out, vibration issues can arrise
I'm looking for a little more clarification.
I'm wanting to dyno my truck but the only AWD chassis dyno thats even remotly close is a $100 ferry ride plus 4.5hrs each way driving and I'd have to cross over into the US to get there, which I'm wanting to avoid.
Buddy of mine owns a shop and has a 2wd dyno that I'd like to run on. Basically want to know if I can run with the front propshaft removed without causeing damage to anything. And if I do remove it, do I need to put anything into the transfer case to keep anything from leaking out on the drive out there and during the subsequent dyno runs?
I'm hopeing I can slide under my truck, mark it, unbolt it and run it without any issue's. The biggest reason I'm asking would be that I use this truck 6 days a week to work.
I've taken a '98 Subaru 2.5RS, '90 Nissan Skyline GTS-T off the line with this truck, and can keep up to a '98 Lexus SC400 that just ran a 191WHP on said dyno minutes before. So I'm now very curuios as to what my truck is putting down for HP.
Thanks for any info
I read in the faq
Thanks for any info
