Re: Revs per mile?
3/16" (or 6/32") is the difference between fresh and worn tires.
For reference, our 2006 Audi A4 specs a 5/32" MAX allowable tire wear difference (front to rear) in the manual. It has a Torsen center diff I think (Not sure EXACTLY what is in ours, but I know some of them had the Torsen, so I assume the spec is written for that model). I'm certain from both an engineering and practical application standpoint that the viscous Coupler in the Sy/Ty usage is more forgivving than a torsen would be, although some additional heat buildup might be a concern in the viscous coupler.....resulting in the need to change the fluid more often.
You'll be fine with a 3 revs/mile difference. If you like I can do the math on how many extra rotations of the VC that is per mile/year/decade/etc
BTW, deleting posts because you're mad or wrong is dumb. If you make a mistake, own it, then make it right. Its the only answer
