Removing transfer case question
2500avalanche
Well-known member
I have a leaky transfer case (where the 2 parts are pressed together). Leaving a lot of fluid on the ground.
How hard is it to take off, and re-do the seal? It looks like a rtv sealent of some sort.
When taking it off, any precautions?
Any other gaskets I should replace?
THanks, just tired of leaky spots on the ground!
atkonkler
Is this your bush?
Re: Removing transfer case question
You must buy what gm calls an adapter seal for between the two. It's not too hard if your using a hoist or even doing it on the ground.
Logan
Have a second set of hands or put a jack under the side where the yoke for the prop shaft comes out to hold it in place. I would drain and refill on the ground (don't remember capacity) and I used RTV with success.
Aeroking
e.i.
you have to rotate the case almost vertical to clear the crossmember. I bench press it when i take mine in & out, lots of fluid running everywhere.
Quickstop [UK]
Combating adversyty.
Wrap it in a bin bag before you pull it off. Rotate it and then pull it out - lot less messy. Don't recall the seal being anything special. RTV for when it goes back on.
Sy-1177
Turbo Inside
Mine just started leaking in the Sy right after the Ohio meet. I will be redoing mine also. Its not that hard to get out, just akward.
91blazins10
There is a gasket for it, I used one when I did mine. I don't have the part# for it though.
Gnocide
turbo game burt reynolds
mine started leaking this year so i too need to do that.
2500avalanche
Well-known member
For anyone that has done this... How long to do so? About 5 hours or so? I know how to take the prop shaft off, but any suggestions with the drive shaft?
Thanks
Jimmy
Banned
It's just a 4x4 transfer case to tranny seal cheap at dealer all day long.
Disconnect propshaft from transfer case. Remove 4 bolts from rear end yoke to drop driveshaft.Disconnect bracket on top of case that holds fuel lines.Take off trans to case brace.Disconnect electrical connector. I always drop the PS of the trans crossmember to facilitate removal.. Take out 5 bolts that connect it to the tranny,drop it out then put everything back together. Couple hours or so.
