Rebuilding a PS pump
jjorgensen52
NHSTE - I'm the only one!
As promised, I finally did this and took a lot of pictures. This applies to any Saginaw P series pump (all GM models, pretty much). The one I did was metric, but it doesn't make much difference. I bought a generic rebuild kit (cost me about $12 shipped) with shaft seals.
Okay, so first take it apart :lol: . Pretty self explanatory, you have to compress the rear cover to remove the spring retaining clip, then the whole thing pretty much will fall apart. The impeller is held to the shaft with an external spring clip. Hammer out the shaft, and you're left with the case and a press fit sleeve. I used a 1/2" drive 14mm deep socket to drive this out with a hammer.
Here is the entire pump, exploded
At that point, you're here, and ready to insert the new sleeve
Press that in (I used a washer and a socket to set it in all the way, just in my bench vise)
That done, insert the shaft ( I had to clean some scoring on mine, no big deal) and tap it into place with a hammer. ( seats until the shoulder on the splined end is flush with the case)
Next in line is the shaft seal. I just tapped it in with a hammer, would have been easier with a big socket
Next comes the lower vane and the 2 vane locating pins ( I made sure to coat each piece with fluid as it went in)
then, the actual impeller. This is a slotted wheel with 10 little sliding vanes in it (they like to fall out, be careful.) retained on the shaft with an external spring clip
Next, slide the impeller housing into place over the vane locating pins
Then, the upper vane O-Ring, followed by the upper vane
jjorgensen52
Re: Rebuilding a PS pump
Part 2
After that, the rear cover O-Ring goes in
Then the pump preload spring
rear cover
Press the cover down (easiest with a clamp) to facilitate installing the spring retaining ring
remove the clamp, and you're set for the internals
next in is the flow regulator valve
followed by the regulator spring
Install new orings on the three threaded bosses, and the main body o-ring, then the resevoir goes on.
after that, the outlet fitting threads in over the regulator spring
At this point, you're basically done. Just reattach the two pump mounting studs (through the resevoir) and you're good.
MikeRenz
not stock
neat. but why not just grab one from a jyard for $5 and save yourself 5 hrs of labor?
George Blake
DONATING MEMBER
Because the one from the JY may be fubar as well. I'm gonna do this with the ZQ8 I bought just to prevent headache later.
4C FED
Absolutum Dominium
Great, I took mine apart about 4 months ago. Now I can see how to put it back together.
jjorgensen52
It took me about 1 hour and 20 minutes to do, total, not counting the part where I couldn't get the outside spring retainer out :roll:
It was a brand new AGR pump, which I installed in my Ty and it started leaking about 5 minutes after that. They wouldn't fix it, so I figured I would rather than buy another pump
QWERTYphoon
Motley Driver Award 2009
I did the AGR pump with ZQ8 steering box, sweet setup. I took my old pump apart, looks just like the pictures. lol
