Re: R134a Conversion
jimmyz79 said:
Anyone done this themselves? I saw the kit at the store - Gotta be more to than that.
You are correct, atleast to do it CORRECTLY anyhow.
jimmyz79 said:
Need some input.
Stupid EPA (jus' venting)
Do a search on the WWW for R12 to 134a conversions.. There is alot of information out there. From what I have read or been told there is alot more to doing it than that KIT.
Heres what I know:
1. Change the Drier Assy (R12 oil isn't compatible with 134a oil), also the dessicant is prolly getting old and useless if its been in use for any time..
2. Change the Orifice tube assy... Something different with the flow rates
3. Have the system Evacuated professionally, reason for this moreover than making the tree-huggers happy is, when you evac the system it also removes any internal moisture that maybe accumulating inside the system, as you lower the atmospheric pressure water boils easier and at lower temps. This allows regular ambient temps to be enough to remove most of the moisture in the system therefore preventing "FREEZE-UPS" etc..
4. Change the fittings using the setup you more than likely saw in the store, this allows for the correct sized gauges to fit. (ie the 134a gauges vs the R12 gauges)..
5 <OPTIONAL> Change out the condensor with a larger one, supposedly the R12 refrigerant is more effective than 134a, allowing a smaller condendsor, I've heard claims that people recommend changing to a larger unit. I myself would skip this step and just complete the first 4 listed above.
Sure you can just vent the system to atmosphere and screw on a couple of schrader type fittings and refill it.. Problem is, overall performance will suffer due to mix-matched refrigerants and incorrect parts.
Hope this helps.. Its really quite easy to accomplish and in the oncoming years you will enjoy the ease of rolling up to any autoparts store and topping the system off with ease for CHEAP.
