Question about solid motor mounts and tranny removal
spooldup
Super Member
Just wondering. With stock motor mounts you can let the tranny hang down a bit to get access to the top bell housing bolts because the mounts are rubber right? So if you switch to solid mounts how do you get to the top bolts seeing as how the motor won't move?
ItsMyTy
Life is beter at 25 PSI
yea i use box end wrench, sometimes a stubby wrench from the bottom and top
they shouldnt be very tight, 35lb/ft or so
scotts4
ADDICTED
i just did my tranny and i have solid mounts . I used a lift but a long extention with a swival socket worked fine .
ed hess
race or get outta the way
motor mounts dont matter. just undo 2 body mounts on drivers side of cab, lift cab an inch or so and take bolts out. even the service manual says to do this.
ed
MikeRenz
not stock
maybe for a sy...
spooldup
Super Member
Thanks guys. So i guess it's not that bad. How does the truck feel with solid mounts? Vibration?
MikeRenz
not stock
did you get a solid tranny mount to match your motor mounts?
I've ridden in a sy w/ all solid - no vibrations out of the ordinary. His exhaust resonance tone was way louder - but i doubt thats really a factor of the mounts
spooldup
Super Member
no i didn't. Who sells them? Can i use a solid mount for the trans and not for the motor if i don't install my new engine right now?
MikeRenz
not stock
You can, but most people match up the type of mount their using. The solid tranny mount may be slightly different size than the poly mount if i recall?
