I think my torque converter is going out. I have been having a problem where the ty won't shift till like 3000 rmps no matter how fast I am excelerating. I was spooling at a light, showing off, and after that, bigger problems. If I am stopped, it won't engage and start moving forward until I rev on it a little. Then, if I stop, I can feel it dis-engage. I still have the problem with it shifting gears high. I tried to excelerate hard from a stop and it made a noise like if you grind the gears in a stickshift.
Well here is the problem, I no longer trust any place to work on my truck (because of too many previous problems). So, me and a buddy started to pull out the tranny yesterday but ran out of daylight, so I plan on finishing it today to where I can get the torque converter out. So I disconnected the two electrical plugs, all six bolts that go to the cross member, disconnected the front and rear drive shafts(the front fell down, but the rear seams to be stuck together), and taken off the converter cover. All I think I need to do today is drain the trans fluid and disconnect the tranny from the motor. My questions are:
1. Is there six bolts that hold the tranny to the motor?
2. Do I need to disconnect the tranny lines before I drop the tranny?
3. Does the rear drive line just pull out the tranny once its disconnected?
4. Once the tranny is sepperated from the engine, will the TC just pull off?
Any info on this would help, cause this is definately going to be a learning experience for me. Thanks guys
