Q about greasing the Prop Shaft
syntax
I found what seems to be a set screw on the side of the Double C Joint, i removed it and It seems to be the grease port, Am i Correct in assuming this? If so do i just need to get a needle greaser for my gun and go to town on it? Grease it up until I see new grease coming out of the joint sides? Anything else I need to know or Am I on track? First timer for this, Thank you.
Tooky
Serious about performance
Re: Q about greasing the Prop Shaft
Hey Kevin!! Drop me a line on AIM sometime! Yes you need a needle grease point. I'm not sure how much to put in - but if you overdo it until it shoots out the side, you'll have grease splattered ALL over the underside of your truck due to centrifugal force!! (happened to me) I say squirt it conservatively! 1-2 good pumps and call it a day IMO.
DaveP6999 would be the best guy to answer this.
