syclone rider
I searched this question and couldnt find anything on it so ill just ask will a ty front propshaft fit a sy?
Good to hear thanks for the help.Yep, same thing.
I think your right cause the sy front shaft is telescopic it will move in and out but the ty one doesnt.i thought the sy t- case was a little longer? which would move the propshaft mounting flange rearward, thus making the ty propshaft too short. am i wrong?
There is about 2" of slip in the shaft to help get it in or out. The shafts are definately the same. The big U joint goes towards the back and the slip joint towards the front. It should pop right in there unless something else got messed up when your last one broke?Well the reason why im changing it is because my stock one broke do you think maybe it bent something or does the bolts pull everything back together
Ok ill try it tomm i got pissed messing with earlier so ill get some sleep and maybe have better luck tomm.There is about 2" of slip in the shaft to help get it in or out. The shafts are definately the same. The big U joint goes towards the back and the slip joint towards the front. It should pop right in there unless something else got messed up when your last one broke?
Nah its the stock trans why does my sy shaft look totally different than the ty?Have you got a 4L80e in it? If so, then the transfer case will be 3.25 inches towards the rear and a stock shaft will be too short.
http://i926.photobucket.com/albums/ad108/syclonerider/Parts/Driveshaft.jpg Heres the one that came off my Sy and my ty one doesnt look like it.The ty looks like the one you would buy off ebay for a sy or ty.
