just a 6 said:
Could you please explaine to this stupid swede what you meen. We are talking about $270 differens here, why is it so much better and is it worth $270 ????
bdubb said:
you get what you pay for.
You get a tank & mount (not a big deal, but it adds up)
You get steel braided teflon line, rather than rubber hose - this is a biggie in my book. I'm not going to run rubber line the length of my truck with high pressure propane in it. AN fittings & such isn't cheap. That right there is probably $100.
The nozzle in the OGS kit is easy to mount, no tapping, you can even put it through silicone or nomex connectors if you don't want to drill into intercoolers or pipes.
In-cab controller, for arming the kit, adjusting turn on point, and the biggest feature, an adjustable duty cycle solenoid. So instead of just tuning pressure, you can adjust the solenoid's duty cycle.
The solenoid & regulator are custom pieces, not off a shelf, for propane, and the regulator has a larger range.
OGS will be offering the remote gauge as an option, and will probably have a tank heater system in the future too.
I think the IPO kit is fine, and works, but I like the parts & features of the OGS setup better.
So in my opinion, you do get what you pay for.
