B
Blake
Guest
I'm in the process of porting a set of L-35s. When I disassembled them for cleaning I noticed that in the combustion chamber, on the sparkplug side, there was a "dead spot" on the outermost edge toward the cylinder edge. It was full of carbon. I knocked down the raised seat of both intake and exhaust ever so slightly because they were raised nearly an 1/8th inch. I'm trying to polish these areas out so carbon formation won't be so prevalent(detonation fear)after I get them on my Ty. Does anyone have any idea why these two pockets were left so deep?
Exhaust porting is easy and needed a lot of help due to poor casting on the heads I have. I squared up the exhaust ports a little since they taper inward at the top. Don't know why they did this. Most everything I've read said that most flow is in this area of the port. Easily seen why when looking straight through the exhaust port from the combustion chamber side.
Intake ports left of LOT of room in the "bowl" area for improvement. Not much to do on the intake runner entry since it almost matches the gasket already.
I'm sticking with stock sized valves due to shrouding problems associated with our cylinder size. The bigger valves are supposed to actually become a restriction until higher lifts(over .500)are obtained.I did go ahead and slightly deshroud the combustion around the valves just a little(mainly to take the sharp edge off the "cliff").
Also laid back the edge of the combusion chamber opposite the sparkplug. The top edge actually curled over into the combustion chamber and was razor sharp. Hopefully smoothing it a little helps also.
Like many have said. They is no comparison between the L-35s and the old L-B4s. With the Sonoma GT being available with the Central port injection, I don't know why GM didn't go ahead and use these heads(L-35s) on the SyTys after they went through all the other trouble. Doesn't make any sense. Oh well. Hope this opens some ideas on what to do(or NOT to do)when setting up a setting up a set of heads. These were about $150 with 36K on them. Please give out any ideas on what to do/not to do with the porting techniques.
Thanks,
Blake
Thanks,
Blake
